Postive or Neg ground on Farmall 400 and AC D19
Bill Porter
07-08-2001 15:28:06
Hi All, I put a new batt in both of the above tractors and as there was not a batt in either of the tractors I put them in as Neg ground but now they
start but both charge backwards, or else the gen has failed on both. Are they Postive ground?? A dumb Texas Redneck
Bill
Bill Porter
07-15-2001 09:34:21
 Re: Postive or Neg ground on Farmall 400 and AC D19 in reply to Bill Porter, 07-08-2001 15:28:06
Hi All, Thanks much for your help. Changed cables and am
now working right.
Bill
Glenn(WV)
07-08-2001 19:07:45
I'm not sure about the D19, but the 400 is a positive-ground tractor. HTH
steve
07-08-2001 18:02:19
yes, all the 12 volt tractors from the 1960 era were positive ground also. OUr D17 is that way. You can connect it negative ground, but like you say it will show backward on the amp meter. Not sure what you did to the generator. It should know it is positive ground. Not good to connect it up backward. If you go to negative ground you need to get a different generator or alternator. Best to connect the batteries to positive ground now.
paul
07-08-2001 15:48:11
most all 6 volt tractors have a positive ground, try switching the bateries, if that doesnt work you might have to re-polarize the generator
