Hydraulic problem on AC
CA
bern
07-05-2001 08:40:43
I just purchased a 1952 model Allis CA. The problem is one of the 3pt hitch hydraulic cylinders stays extended no matter what position the hydraulic lift lever is in. I have a manual that shows the adjustments for the hydraulic lift. Could this be the problem, (out of adustment), or could there be something wrong in the hydraulic valve?
KURT
07-06-2001 17:18:38
 Re: Hydraulic problem on AC - CA in reply to bern, 07-05-2001 08:40:43
If one cylinder is working and not the other and one valve controls both cylinders then that one cylinder may be binding up and you would have to fix it or the linkage in the 3 pt is binding.
Howard
07-05-2001 16:34:10
Hi Bern,
I've had a '52 CA for a year, hydraulics didn't work at all until I drained the fluid by removing BOTH plugs and refilling with new fluid. You might want to loosen the packing nut on that ram and see if there's anything in there that shouldn't be, like rust. The manual specifically says not to overtighten the packing nut -- maybe because if it's too tight, it could keep the ram extended. It should just be tight enough to keep fluid from seeping out. Good luck!
