D17 started to run bad
fw
07-05-2001 06:37:23
backfires through exhaust, cleaned carb, air filter ran good for 45 min, but now it runs
bad all the time. cuts out, backfires, spark plugs
are black with carbon.
Duey (IA)
07-05-2001 10:15:24
 Re: d17 started to run bad in reply to fw, 07-05-2001 06:37:23
fw, Backfiring normally indicates lean fuel mixture BUT with carbon on the plugs it indicates poor ignition. Sounds like time for a tune up. I would install new points, condensor,and plugs. Check dist. cap and rotor for carbon tracks that indicate shorting out. If the problem continues check the coil. Duey
Farmer-Gene
07-05-2001 07:45:39
check dist points
fw
07-05-2001 08:48:31
 Re: Re: d17 started to run bad in reply to Farmer-Gene, 07-05-2001 07:45:39
i forgot to say i checked the pionts also, gap
was ok, didnt clean them
