Need help with WD45 brakes
DaveWestlund
06-30-2001 19:20:24
I finally got out the bottom pin, but cannot pull the brake shoes out throught the top opening. Is there a secret to this? Thanks for your help!
Tom
07-02-2001 17:38:53
 Re: Need help with WD45 brakes in reply to DaveWestlund, 06-30-2001 19:20:24
Well this weekend I got the bottom pins out of the brakes on the WD I am working on. I ended up drilling and tapping the pin and using a grade 8 bolt and 13/16 socket to pull the pins out. First I had to grind about 1/16 inch off the head of the pins, they are case hardened. Then drill and tap a fairly deep hole to allow enough threads to get a good grip on the bolt, didn't have a stud and threaded rod was not tough enough, and use a grade 8 bolt and pull them out. still wasn't easy. I would recomend that before installing these pins , with a lot of grease or anti seize, drilling and tapping, it will be a lot easier with the pins out than trying to do it with them under the tractor. If not you, someone will be glad you did it someday.
Dave K
07-01-2001 09:51:24
Did you disconnect the brake rods? Once you remove the springs, bottom pins and rods each shoe should slide up and out easily, one at a time. It is those bottom pins that are the bear! You have to remove the adjusting nut from the clevis(on top) and remove the front shoe first. Dave
Dave westlund
07-01-2001 13:30:38
 Re: Re: Need help with WD45 brakes in reply to Dave K, 07-01-2001 09:51:24
The brake rod was broken off.That is why I'm doing the repair. You are right the only way I could get that rod oput was to weld a bolt onto the pin and then use the bolt as a puller.
Thanks I will try to get the front shoe out first!
Thanks
