Power steering D-19
J.G
06-28-2001 19:45:44
The power steering on my D-19 diesel is beginning to act up. Most of the time it works good then it will start acting like it has no power steering at all. I checked the fluid level and it is full.Any suggestions . Thanks
Dave in IL
07-02-2001 06:07:25
 Re: Power steering D-19 in reply to J.G, 06-28-2001 19:45:44
Check your power steering pump pulley, it may be loose. My D-19 had the exact same problems and that was the culprit. I had to have the hole in the pulley welded closed and redrilled to fix. Fortunatly the pump shaft wasn't damaged. Good Luck, Dave
