AC 190 XT
ED VOGT
06-27-2001 16:51:14
tractor starts but then quits.The injector pump has been rebuilt,injectors rebuilt,and new fuel filter installed.Also put in all fresh fuel.It runs for different short periods of time.
Chip
06-28-2001 19:38:05
 Re: AC 190 XT in reply to ED VOGT, 06-27-2001 16:51:14
Try unhooking the return line at the pump. Could be plugged or crushed. If it has an air leak, it more than likely won't restart.
Good luck!
tim landauer
06-27-2001 20:34:36
i would check the fuel line for air leaks . check the fuel tank outlet for blockage .
check the gasket on the glass sediment bowl on the bottom of fuel tank .
we had a model m crawler that would just stop running now and then for no reason . we found some crap in the fuel tank that would work it's way over the fuel outlet hole . after a million hours of cleaning it never did it again .
