Delco-remy generator on an A-C b
Nick
06-27-2001 08:20:28
I need detailed wiring instructions for a Delco generator on an AC B. I have the wiring diagram for the tractor but it does not go in to great detail about wiring the generator. The generator has two terminals, both of these have continuity to the body of the generator, is this a problem?
Any help would be greatly appreciated.
-Nick
steve
06-27-2001 16:01:27
 Re: Delco-remy generator on an A-C b in reply to Nick , 06-27-2001 08:20:28
The A terminal goes to the cutout relay bolted to the generator and it routes to the battery. The "F" terminal goes to the head light switch which is a variable resistor to ground that controls 2 amp charge when off and 10 amp charge with the lights on. I will send you the drawing on e-mail
