Serial number for WD
Gene Heckemeyer
06-27-2001 07:02:20
Could someone tell me precisely where to find the serial number for a WD and WD 45. Also, I have a restored WD with a curved shifting lever like a WD 45. The WD is a 53 model; could it have been manufactured with the curved shifter or was it added later?
Farrell (Utah)
06-27-2001 09:41:33
 Re: Serial number for WD in reply to Gene Heckemeyer, 06-27-2001 07:02:20
You can find the serial number on the vertical
section of the rear end directly behind the left
plate that gives you access to the brakes. It is a flat area and may be covered with paint but it is there. WDs starting with serial # 127007 had the curved gearshift and the constant-mesh transmission. All 52 and 53 model WDs with serial numbers from 127007-146606 would have the curved gearshift.
