WD Power rims
Bob
06-24-2001 07:20:38
I need new rims, Tire size 13.6.28, fluid finally got to them. If anyone can give me a address/email/phone Number I would appreciate the help. I am in Northern MN. Bob
Mark from MN
06-26-2001 22:06:46
 Re: WD Power rims in reply to Bob, 06-24-2001 07:20:38
I have found new rims for $230 at Larson Implement
in Cambride MN. I'm not sure how far north you are but you might want to give them a call. I'm in the same boat as you. I just need to convince the wife that the tractor really needs the extra $$$. Maybe she will agree when I make her shovel a 2000 ft. long driveway this winter because the tractor just spins!!!!
oldtimer
06-26-2001 19:59:00
I just got a wd going,If you don't need the power wheel adj. do what I did on one of my WD's Go to a combine salvage and get some combine wheels and tires,I used 14.9x 26 look good and work fine,I have some old E gleaners behind the barn that I got them from.There are other old small combines that use the same tire and wheel
Bob
06-26-2001 03:47:57
Thanks folks, Just when I had exhausted the local area and went to you, my son come through with help from a local farmer. He found some that were complete, removed from the axle, so hub, center, rim and tires with no c/c in trade for a little farm laboer. Since the tractor lives at his house most of the year it worked out great. I did get a lot of offers for new rims. So if any of you need address for those let me know and I will post them. Bob
Dan
06-24-2001 19:37:38
New rims are available at M.E.Miller tire. check out www.millertire.com
They are about $200 each in their new catalog. I have repaired some rims by cutting out the damaged section and taking an old wc allis rim and cutting out a good section, weld and grind and paint to look not as good as new but very servicable for farm work. good luck.
Tom
06-25-2001 18:19:47
 Re: Re: WD Power rims in reply to Dan, 06-24-2001 19:37:38
This is my plan. I have 3 rims that I will need to pick two from, and a fourth that I plan to cut up for patches. Haven't got that far on my project yet though. I plan to get the two rims to be used well sandblasted though before I start cutting and welding.
Tom
06-24-2001 18:33:18
I have herd of using a standard rim and taking the spiral bars out of the other (old) rims and welding them into the new rims. You would have to make sure the diameters are the same though.
Because AC put calcium in the tires for the added weight a lot of us have had to deal with this. I have found that old anti-freeze that you save and collect works well, it isn't as heavy, but it won't eat the steel if you get a little leak or happen to leave a drop of it on the rim.
Jamie
06-24-2001 15:08:08
I am in the same situation. I found some through CT Country, one for sure in Owatonna. They run $300.00 per rim. I am looking for some used ones not a lot of luck as yet. Good luck with your search.
