AC just stopped running!!
Home veggie
06-23-2001 15:04:45
I need HELP!
I was driving my 1951 AC and it just died. It is if I turned it off. It was running fine before, started right up ran good.
It has no switches, just magneto.
Does anyone have a clue as to what happened? It will turn over but will not start.
Sandy lake Implement
06-24-2001 02:02:22
 Re: AC just stopped running!! in reply to Home veggie, 06-23-2001 15:04:45
Did u check for spark? If it starts up again after cooling down my bet is the mag coil!
We can fix u up with a new one. Bill
Zeus
06-30-2001 00:05:02
 Re: Re: AC just stopped running!! in reply to Sandy lake Implement, 06-24-2001 02:02:22
I agree with Bill.
In every case I have seen where a spark ignition engine suddenly stopped running (except those vehicles w/ electronic ignition systems), it was due to one of three things: out of gas, burned ignition breaker points, or weak ignition coil (usually shows up after engine has run for short time & coil has heated up).
Mike Wurth
06-24-2001 07:59:55
Would you happen to have a Wico EK for a Wade dragsaw handy? How much?,,,,Mike
Sandy Lake Implement
06-25-2001 06:29:07
 Re: Re: Re: AC just stopped running!! in reply to Mike Wurth, 06-24-2001 07:59:55
We only trade in the FM 4 cyl mags for our AC tractors. As suggested by Tom, contact Mark- we
regard him highly. Bill at S>L>I
Tom
06-24-2001 18:37:16
If you need a mag and can't find one try Marks Magneto Service. 395 South Burnham Hwy. Lisbon CT 06351. 860-887-1094. Many mags are $150 exchange, if he can't fix yours. Mark has done well for those of us in this area, and he does deal nationwide.
Dick L
06-23-2001 16:17:59
Mine did that last year going down the track at a pull. Fixed that problem with gallon of gas. It didn't do much for the red face.
You might take the gas line off at the carb to see if you have a good flow. If you do take a spark plug wire off and see if you can get a spark from the wire to the plug. Those two checks will let you know what direction you need to go to find your problem.
