Hard steering wd45
zeke
06-22-2001 20:44:39
have wd45 with wide front end that turns really hard any ideas
steve
06-23-2001 18:48:43
 Re: hard steering wd45 in reply to zeke, 06-22-2001 20:44:39
take the long steering rod off from gear box to the front axle. see if the steering wheel and gear box turn freely without wheels. jack up th efront end and see if each wheel turns freely side to side. this will tell you where the problem is at.
Nick
06-27-2001 08:22:52
 Re: Re: hard steering wd45 in reply to steve, 06-23-2001 18:48:43
WD 45's are generally very hard to steer if they have a wide front end.
zeke
06-24-2001 04:37:30
thanks for the imformation ill give it a try
Rick
06-22-2001 23:02:52
Zeke, Here are a few things to look for. Make sure the steering box is full of oil. If it is really low or out of oil, this could cause hard steering. Make sure all hub bearings, inner and outer,are in good shape and do not have flat spots on them or a roughness to them. Make sure that the tie rod ends are tight and not loose. Also make sure that they are not frozen up. Check to make sure the steering plate under the front of the tractor is tight and not sloppy loose. Low air pressure in the front tires will also cause stiff steering.Plus, if you have power steering, make sure it is full of fluid. The reason for the long paragraph is that everything I mentioned here has happened to me! Hope you find your problem. Thanks, Rick
zeke
06-25-2001 04:35:50
 Re: Re: hard steering wd45 in reply to Rick, 06-22-2001 23:02:52
thanks for the feedback ill give it a try
Tom
06-25-2001 18:22:17
 Re: Re: Re: hard steering wd45 in reply to zeke, 06-25-2001 04:35:50
WEll let us know what you find, I for one am interested!
Tom Miller
07-01-2001 21:34:41
 Re: Re: Re: Re: hard steering wd45 in reply to Tom, 06-25-2001 18:22:17
Someone must have put grease in the gears but if you take the weight off of the front, and take the top bearing out or as far as you want to go, and then clean the grease out and replace with 80W-90 gear lube and work that in with no weight on the wheels and it will get easier.
