C governor spring
Darrell
06-22-2001 08:09:10
I just bought a '41 C with the engine rebuilt. There is a spring from the governor rod which runs down behind the carburator. It has become detached. Can anyone tell me where it is supposed to hook?
Sandy Lake Implement
06-22-2001 17:42:25
 Re: C governor spring in reply to Darrell, 06-22-2001 08:09:10
The spring goes as vertical as possible to a manifold stud. Bill
Darrell
06-22-2001 17:51:10
 Re: Re: C governor spring in reply to Sandy Lake Implement, 06-22-2001 17:42:25
Thank you , that's what I needed to know.
Darrell
Dale E.
06-22-2001 10:05:23
Darrell, I think there should be a hole in the linkage arm that hooks to the throttle shaft. Probably needs a cotter pin stuck in and bent lenght ways with the linkage to hook to.(Didn't say that good. The hole is in the shaft just ahead of the carb.) None of mine have had this spring so I'm not sure. Hope that helps.
