Model CA carb questions
kent
06-20-2001 05:58:11
Does anyone know the proper setting for the float level of a 1952 model CA allis? I don't believe it's a marvel schebler carb, I think it is another brand and it is original to the tractor. The high speed mixture is not adjustable and I think the float level may be making the tractor too lean. thanks, Kent
kent
06-21-2001 08:42:58
 Re: model CA carb questions in reply to kent, 06-20-2001 05:58:11
thanks very much everyone for your help. I can hardly wait to try it this weekend. I have the Zenith carb.
bkzap
06-21-2001 07:32:25
What you need to find is a Zenith 161J7 carb.
Size is 7/8" and it is a Main jet fixed. Float leval is 7/16" from the top of the bowl. To top of the fuel or 1-5/32" from top of the bowl to bottom of float.
OR If you have a Marvel-Shebler TSx486 Float leval 7/16" from the top of bowl to the top of fuel, or 9/32" from top of the bowl to the nearest edge of float.Idle jet turn in to rich out to lean.main jet is fixed no adjustments. These notes are taken from the Aliis Chalmers shop book #79003403 that can be bought from your A/c delar.
Dick L
06-20-2001 07:21:57
carb float post
Link
copy and paste in your browser or change the 25021 in your browser to 24547
kent
06-20-2001 08:29:29
 Re: Re: model CA carb questions in reply to Dick L, 06-20-2001 07:21:57
Dick, thanks very much for the help. your link shows a picture of a float mounted on a carb top but the diagram doesn't actually give a measurement. It just says "float setting". maybe there isn't any measurement spec and the float is just set level to the carb body? is that the case? thanks in advance, Kent
Dick L
06-20-2001 12:39:20
 Re: Re: Re: model CA carb questions in reply to kent, 06-20-2001 08:29:29
That is what it means. Set it parallel to the parting line of the top of the carb, holding it upside down.
