Wd 45 loader hookup
mitch
06-19-2001 09:53:03
I have a WD45 that I am restoring for a friend and it has a very nice Allis Chalmers loader with it. The previous owners had a hydraulic unit welded to the crank pulley to power the loader hydraulics but the pump apparently quit working and was removed. We haven't been able to locate the pump and I am wondering what is the best way to go about plumbing in hydraulics to get the loader running again. The loader has its own remote so I just need to get the oil flowing to it. But it doesn't appear as though the tractor's hydraulics would be practical. Should I go with a PTO driven pump or try to hook something back onto the crank pulley? Any ideas would be greatly appreciated.
Brian G. NY
06-20-2001 06:57:44
 Re: wd 45 loader hookup in reply to mitch, 06-19-2001 09:53:03
I run the loader on my WD with the tractor's original hydraulic system and it works fine; albeit, it's a little slow. I am seriously considering istalling a pump on the crankshaft so I can more easily install a hydraulic controlled bucket instead of the "trip" system I now have. I would say definitely go for the crankshaft mounted pump; there's nothing like true "live" hydraulics. Besides, you already have the adaptor on the front of your engine!
kent
06-19-2001 10:41:17
I have a 1954 WD with a stock allis chalmers loader. It is powered from the stock hydraulic pump in the tractor. It works great, no complaints! I'm not sure if you're hydraulic system is the same as mine though. Kent
