Allis Chalmers WD 45 transmission
Gene Turk
06-13-2001 12:00:45
I own a 1954 WD 45 that gets stuck in a forward gear. I can shift into reverse but am still in the forward gear at the same time. I see this may be a common problem with this year and model. I have removed the shifting lever plate and forks. It appears that a collar on the front of the gear assembly mass is sloppy and may get hung up on top of the tapered protrusions of the formost gear. If this is the problem how do I remove those parts for replacement? It looks as though the entire assembly should come out the back through the plate on the rear axle housing. If anyone knows how to go about this I would welcome a basic walk through of what to do. Are transmission parts available through AC dealerships?
Tom Miller
06-15-2001 22:10:02
 Re: Allis Chalmers WD 45 transmission in reply to Gene Turk, 06-13-2001 12:00:45
I think your problem is that the pivot is getting sloppy and causing the lever to switch gears.
AL
06-14-2001 06:30:10
CHECK THE ARCHIVES OF THIS SITE OR THE STRATTON UNOFFICIAL PAGE...AL
Farrell
06-15-2001 08:08:31
 Re: Re: Allis Chalmers WD 45 transmission in reply to AL, 06-14-2001 06:30:10
I have a torn-down transmission and may have the
part you need. Let me know the part number and I
will check.
