Help! I took my magneto out and don't know how to set it in.
Marvin
06-12-2001 17:48:39
How does the magneto on my Model B go back in, and how do I know it is not 180 degrees out with the engine? Is there any trick to getting it timed again?
Unimog
06-12-2001 18:47:40
 Re: Help! I took my magneto out and don't know how to set it in. in reply to Marvin, 06-12-2001 17:48:39
Here's the way I do it, crank the motor until #1
piston is producing compression(finger in hole) to
top dead center and the timing mark(Fire, in hole
on left side flywheel). Next remove sm. cap and
turn the rotor till it lines up with the lug(left
top). The drive lugs(where it drives mag) should
be in the horizontal position and the mag can be
installed to the motor
Unimog
steve
06-12-2001 18:53:58
 Re: Re: Help! I took my magneto out and don't know how to set it in. in reply to Unimog, 06-12-2001 18:47:40
It is probably obvious to most, but with the no 1 piston coming up on compresion and the "fire' mark sighted in the hole, your mag is pointed at the number 1 spark plug wire on the cap (or the top lug as mentioned above)
Marvin
06-13-2001 02:51:35
 Re: Re: Re: Help! I took my magneto out and don't know how to set it in. in reply to steve, 06-12-2001 18:53:58
Thanks for the support on how to put the magneto back in, I will give it a try!
-Marv
Greaseman
06-13-2001 06:27:11
 Re: Re: Re: Re: Help! I took my magneto out and don't know how to set it in. in reply to Marvin, 06-13-2001 02:51:35
Hey Marv if it works please spend a few minute and tell me about it, I also have a B which is a killer to sart and likes to slip time.
Marv
06-13-2001 16:51:01
 Re: Re: Re: Re: Re: Help! I took my magneto out and don't know how to set it in. in reply to Greaseman, 06-13-2001 06:27:11
Sure will if I ever do get it running. Been trying now for 8 months.
-Marv
