Allis model CA-some questions
kent sparrow
06-11-2001 05:59:51
I just purchased a 1952 model CA Allis Chalmers. I have a couple of questions: 1. it doesn't seem like the governor is working properly. when you drive up a hill, it doesn't seem to throttle up. we have a "b" model that throttles up just fine so I know the CA is not working right. the linkage is free but I don't see any adjustments. Any ideas? 2. The camlocks on the wheels are frozen and I want to adjust the wheels. anyone got any tricks for freeing them up? I already broke the hex off of one...guess I can weld it back on. 3. does anyone know of an affordable temperature gauge? I want one but the original from the dealer is $70.00. Thank you in advance for your advice. Kent
Ted Seifert Austinburg Ohio
06-11-2001 10:13:10
 Re: allis model CA-some questions in reply to kent sparrow, 06-11-2001 05:59:51
Remove the bolts holding the excentric casting to the wheel. Probably need to jack tractor up and remove ALL bolts. The rim and tire should come loose with some effort . Then heat the casting red hot . The pin will drive out . If you can get the snap ring off it will be easier. Reassemble with antiseize compound.
