WD carb problem
Kemper
06-10-2001 20:47:14
I just put a kit in my WD carb and when i turn out the idle mixture screw it dies just like you shut the switch off,even if i turn it only a quarter of a turn, the only way it will run is if the idle mixture screw is turned in all the way,it also dies if i close the throttle too fast. did i miss a piece of dirt somewhere? any ideas?
