Serial # what make is it
brad kamienieck
06-07-2001 07:53:38
I bought a allis tractor and have serial # but don't know what make it is could people help me on this please here is the # have got off of it
tractor first
1690288
002764
This is off the motor 1810 587681 serial #
model cckr-ms/27331
Thank you so much
steve
06-07-2001 16:11:42
 Re: serial # what make is it in reply to brad kamieniecki, 06-07-2001 07:53:38
Brad, these look more like casting numbers. You need to look for numbers that are stamped into the case. A good description of what the tractor looks like would help, narrow front end, channel frame around engine and radiator, rear tire size, location of any gauges, number transmission gears, pto lever, and location??? To start with you might look around the rear axle around the brake housing, if you think it was built in the 1930-40 era. If it is a medium size tractor from 1940-1950 look around the transmission shift lever. If it is from the 1960 look on bell housing where engine bolts on. You are looking for a letter or two to distinguish the model, then 5 or 6 numbers after that to get the serial number and determine the year. Such as WC, WD, CA, D15, etc
Dave Grubb
06-07-2001 09:11:08
Can you provide a description of the tractor?
