Trans,hydro,rearend,fluids on WD
Jerry in tx
06-05-2001 17:29:45
what weight and so on is recomended for a 52WD?
Brian G. NY
06-06-2001 06:51:18
 Re: trans,hydro,rearend,fluids on WD in reply to Jerry in tx, 06-05-2001 17:29:45
Transmission, Differential and Hand Clutch: 80EP year round; Cap. 18 Qts. Drain plugs located under differential, transmission and P.T.O. Fill at transmission fill plugs. Hydraulics: Non-Detergent 20W above 45 d. and 10W below 45 d. Cap. 5 Qts. Drain plug under P.T.O. Note: this is a magnetic plug because this fluid also lubricates the belt pulley gears. Clean metal from plug before reinstalling. Also note: Most people use a modern hydraulic fluid today.
Brian G. NY
06-06-2001 07:00:36
 Re: Re: trans,hydro,rearend,fluids on WD in reply to Brian G. NY, 06-06-2001 06:51:18
Oops!! Hydraulic drain plug located under the hydraulic system. Fill cap is the 1/4 turn one with the "bayonette" level indicator. Note: There is also a small drain plug at the bottom of the hydraulic pump control. It's a good idea to drain this as well.
