mike bell
06-07-2001 04:25:56
Re: Re: Re: Re: Re: Re: Re: Re: Model B won't run.....What next?? in reply to steve, 06-06-2001 19:48:50
Here are yesterdays results after the rebuilt carb was put on the Allis Chalmers Model # WD45 just to verify which tractor. Yesterdays start up. Hard to start. Full choke and full throttle. crank it over like mad . will not fire until there is a smell of gasoline comming out the exaust. Then will fire, black smoke pours out of the exaust, and then settles down in 5 seconds and purrs. Turn off the choke in about 15 seconds. The tractor runs , lots of power, bury the front loader bucket and the rear wheels will dig and spin in the dirt when the bucket cannot be pushed any further. Tractor runs with lots of power,no sputtering no missing, runs great for about 1 hour. then it starts to miss. I headed for the shed and shut it down.and pulled the plugs and put in a new set hottest recommended for the tractor by the manual. Tractor won't start again until it sets over night. The removed plugs are solid black except for # 4 cylinder which still has a white insulator.Plugs from 1,2&3 are wet and black, I can put the plug back into # 4 cylinder, and 3 new plugs and after the engine is completly cold,over night, repeat the above start process again and get another hour of a good run, shut down and now all 4 plugs are wet and black and dead. I am sure that the last owner that sold it to me had the # 2and 3 wires crossed and the plugs were dead and it ran on 2 cylinders , how long , who knows, 6 volt, I rebuilt the carb, starter, generator, new intake manifold clean and fresh gasoline ,rewired, set timing and the magneto is in good shape with a slight play in the shaft at the rotor end from some bearing wear I assume. Don't seem to lose oil, but at 1 hour a day can't tell. thats where I am this morning. Any what next sugestions, before I buy the dinamite.???
