Dead Battery on my AC B. Help
Mr Potts
06-01-2001 17:41:10
I have an 1948 AC b 6volt pos. Ground. and I have linked my problem to the light/Charging switch. Is there a way to bypass this switch since I dont have lights on the tractor anyway?
Any help would sure be great or a place that I can get a new one of these.
Thanks Mr. Potts
Ted Seifert
06-01-2001 17:51:25
 Re: Dead Battery on my AC B. Help in reply to Mr Potts, 06-01-2001 17:41:10
If you have a battery that wont hold a charge maybe the cutout relay on top of the generator is not opening when the engine is off . If the relay sticks closed the battery will discharge back through the generator.
steve
06-01-2001 19:31:12
 Re: Re: Dead Battery on my AC B. Help in reply to Ted Seifert, 06-01-2001 17:51:25
there are two terminals on the generator, the "A" terminal goes to the cutout relay which goes to the ampmeter. The field terminal on the generator goes to the light switch. Take the field terminal wire off. install a new wire and ground it to the tracotr frame. this bypasses the light switch and makes the generator charge 10 amps all the time.look at the ampmeter. if that dont work then touch the contact in the cutout relay and see if it starts charging. if that dont work, the generator is bad.
