D15 Hydraulic Front or Side Pump wanted
JD-East Iowa
05-31-2001 15:23:17
Need a Front or Side Hydraulic pump for my D15. Need to add a loader.
Collin
06-05-2001 16:20:23
 Re: D15 Hydraulic Front or Side Pump wanted in reply to JD-East Iowa, 05-31-2001 15:23:17
I have a d-17 with a ford front mount pump on it. I am not sure if a d-15 and d-17 have the same type of pully that mounts on the crank.If your 15 has 4 holes in the crank pully,ford linkage will mount to your pully.If I remember, ford has 3 different lengths of shafts that goes between the pully and pump. Of course you will need to fabricate a mount for the pump itself.Hope this helps. I found that there is a lot more ford pumps out there than A.C.
