Alternator
Mike
05-26-2001 14:19:46
Hello, I want to put an alternator on my A.C model B. Does any one have a picture or a diagram of a bracket to hold the alternator on? I know I will have to fabricate one but maybe someone has a better way of doing it. Any info greatly appreceated.
Butch
05-30-2001 04:32:20
 Re: Alternator in reply to Mike, 05-26-2001 14:19:46
Duey I have a wd that has been changed and can get no spark so would like wiring diagram.Thanks
TONY SILVAIN
05-29-2001 11:32:35
PURCHASED AN OLD WD 45
NEED CHARGING SYSTEM
CAN YOU "PLEASE" BE OF HELP
NEED TO LOCATE
STANDING BY
TONY SILVAIN
[email protected]
Duey (IA)
05-26-2001 20:42:02
Mike, I used the origional bracket like Steve said. A different pivit bolt, some pipe shimms, maybe a washer or two for the base. The top I found was off a car, mostly to get the adjustment slot, but had to be rebent to fit. Also be sure to change the pulley from the generator to the alternator so the wide belt will fit. A narrow belt to fit the alternator pulley will bottom out in the fan and crankshaft pulleys. If you need a wiring digram for the conversion, I have one. Duey
Mike
05-27-2001 18:24:20
 Re: Re: Alternator in reply to Duey (IA), 05-26-2001 20:42:02
Thankyou Steve and Duey for the information. My next question is were on the motor does the generator bracket bolt to? My tractor came generator delete. When I got the tractor it was the basic model. Hand crank and hand brakes. I since have switched torqetubes to put a starter on, foot brakes, new clutch and a battery box. So I'm not to sure were it goes. I did not see an acessory hole in the block.
TONY SILVAIN
05-29-2001 11:30:27
 Re: Re: Re: Alternator in reply to Mike, 05-27-2001 18:24:20
SIRS
WE PURCHASED A WD 45 A FEW MONTHS AGO
IT ARRIVED WITHOUT AN ALTENATOR / GENERATOR
AS SUCH, WE HAVE TO CHARGE UP THE BATTERY
EVERYTIME WE GO TO USE IT
I NEED AN ALTERNATOR / GENERATOR TO FIT OR
OLD TRACTOR
ENGINE WD 327368PA
TRACTOR SN 71206
ANY ADVISE WHERE I CAN LOCATE & PURCHASE???
THANKS IN ADVANCE
STANDING BY
TONY SILVAIN
[email protected]
Duey
05-29-2001 13:43:17
 Re: Re: Re: Re: Alternator in reply to TONY SILVAIN, 05-29-2001 11:30:27
Tony, I sent you a wire diagram with part numbers for a 12 volt conversion, I hope this helps. Duey
steve
05-26-2001 19:32:54
I have done a couple, last one was a D17. I usually try to keep the lower generator mount bolted to the engine. This can be the pivot for the alternator. Usually have to get a different pivot bolt and might have to shim forward to get pulleys to align. Top mount is always hand made for each tractor. usually a strap with slot. Sometimes can use the generator top strap with modification, or build your own. Once i used a threaded rod with a turnbuckel for top mount. It was easly to adjust the belt that way.
