Serial #'s
mike
05-25-2001 17:44:02
the only number I find is on the rear end. it is D222334 , when I look it up in the wd45's no numbers match. am I looking at the wrong numbers , or is this a tractor of many pieces?
jcm
05-25-2001 18:09:46
 Re: serial #'s in reply to mike, 05-25-2001 17:44:02
standing to the rear of the tractor, on the rear end housing between the brake spring hole and the brake adjusting bolt there is a flat spot. scrape or sand to bare metal there should be a number there that is the serial #
LAD
05-28-2001 14:48:06
 Re: Re: serial #'s in reply to jcm, 05-25-2001 18:09:46
I just bought an AC and am brand new to antique tractors. I believe it's a D14, the previous owner wasn't sure. To verify, I tried to find a serial number. I noticed all of the casting have raised casting numbers. However, I did find a stamped number on the left side of the engine near the air intake. It is 149-6988M. The website serial number check for 1959, D14's is 14900. Seem's like this is it. Does this sound right? and is the left side of the engine block a typical spot for a serial number?
Gary
05-28-2001 20:33:49
 Re: Re: Re: serial #'s in reply to LAD, 05-28-2001 14:48:06
The serial number you found on the engine is the engine sn# . A D-14 has a 149 cu in engine. The tractor serial number is on the clutch housing. D-14's were made from 1957 to 1960.
steve
05-28-2001 17:17:06
the D series tractors had the seerial number stamped on teh bell housing where it bolts to the engine. The number should be stamped and start with D10, D12,D14 etc. If it is older B or C it will be stamped by the transmission shift lever and starte with a B or C
jcm
05-26-2001 08:36:29
I must add this is on your left as you stand behind the tractor
