More advice wd45
Mike
05-25-2001 16:56:00
I have got the baby running only to find the lifts not working. fluid is full. I pulled a small plug out and when I move lever it pushed fluid out. where should I start ? this would mean the pump is working if it had pressure right? ... this board has some real helpful advise from you guys. thanks in advance ... mike
Dave-Ontario
05-26-2001 20:27:57
 Re: more advice wd45 in reply to Mike , 05-25-2001 16:56:00
Mike, See if you can corner David Thomas from MO.He's sbout as good as you get with hydraulics especially WD45s. He's here on the board frequently. The best way to proceed is to get a 0-10,000lb pressure guage and check your pressure. If you are not sure how to do it I can scan you the page out of the I&T service manual. Personally I think Dave Thomas is better than the manual. Good luck and let me know if I can be of further help. Dave-Ontario
