Magneto
JVA
05-24-2001 18:24:19
For some reason, the magneto on my tractor only puts power to one cylinder. I have checked the cap and the rotor and they seem fine. What could the problem be???
Duey (IA)
05-24-2001 20:08:03
 Re: Magneto in reply to JVA, 05-24-2001 18:24:19
JVA, Sounds like Steve is right about only one wire being good. Try 4 new wires . Duey
p
05-25-2001 08:22:42
 Re: Re: Magneto in reply to Duey (IA), 05-24-2001 20:08:03
make sure they are solid core wires! suppression core wires will not work well on a magneto.
steve
05-24-2001 18:52:09
take the wire that sparks and put it in a differnt hole and check. Do you only have 1 good wire?
JVA
05-24-2001 19:52:42
 Re: Re: Magneto in reply to steve, 05-24-2001 18:52:09
The wire that sparks will fire any one of the four cylinders. I'm wondering why no other cylinders will fire on their own??!!
steve
05-25-2001 16:20:53
 Re: Re: Re: Magneto in reply to JVA, 05-24-2001 19:52:42
J, are you saying if you put that one wire in each of the three other holes, the mag will fire down thru that wire, but the original wires wont fire? I think you have figured out the wires need replaced.
