wc/wd camshaft
oldtimer
05-23-2001 16:41:51
problem;after getting my wd pulling tractor home last fall after our last pull,I parked it for the winter ,later I had to move it .When I started it up I didn't have any oil pressure. to make a long story short,the oil screen was collapsed, there was a slimmy goo totaly plugging it. Jammed the oil pump, wiped out the gear on the cam shaft. what would cause this? did a friendly loosing puller get to it? Question#2 will a wc cam work in the wd?
Tom
05-24-2001 17:54:48
 Re: wc/wd camshaft in reply to oldtimer, 05-23-2001 16:41:51
I think they are the same. lay them side by side and mike them.If it fits it will work. The cams could be a little different, I don't know about that, but if they fit, the engine will run.
oldtimer
05-25-2001 05:13:21
 Re: Re: wc/wd camshaft in reply to Tom, 05-24-2001 17:54:48
havent gotten them out yet ,but thats what I was thinking, have some cracked blocks I can take one out of, thanks, maybe a combine engine??
