WD 6 to 12 v change ?'s
rw
05-22-2001 12:24:39
In order to convert my WD from a 6 volt to 12 volt system my local contacts tell me I can purchase an alternator with a non-feed back pig tail (that won't drain the battery) for under $50. Change to a 12 volt battery, keep the six volt starter and install a resistor on the lead wire to the coil. Is there something I am missing or something here that you may disagree with? How hard is it to install, do the mounting brackets work and is there space available for the alternator?
Dave Grubb
05-23-2001 06:20:25
 Re: WD 6 to 12 v change ?'s in reply to rw, 05-22-2001 12:24:39
You will definitely need to put a resistor inline for the coil or better yet purcahse a coil with an internal resistor. You will also need to replace the condenser for the points with a 12 volt unit. The condenser will fail after a period of time. This site has some good archive articles on this.
steve
05-22-2001 19:34:36
You basically have the right story. The alternator is probably a "single wire" if you are getting the one without the pigtale (external voltage exitation). The one wire is simple design, a heavy wire like 8 gauge routed directly to the positive battery terminal. Yea the 6 volt starter will be fine and changing from positive gound to negative ground on the tractor is o.k. You may need a resistor in the coil line to drop voltage back to 6 volts. Any light will have to be replaced with 12 volt bulbs. Basically you got it. Biggest problem is building a bracket to mount the alternator and tighten the belt.
Duey(IA)
05-22-2001 16:52:12
RW, I E-Mailed you a wire digram for the 6 to 12 volt conversion. Duey
