B stater spins the wrong way
Chad from TN
05-21-2001 17:47:39
My B starter spins the wrong way how can I fix it.
Mark from MN
05-21-2001 21:03:08
 Re: B stater spins the wrong way in reply to Chad from TN, 05-21-2001 17:47:39
A starter will only spin one way no matter wich way
you have the cables hooked up. It depends on which
direction the winding on the armature are wound and
cannot be changed to the best of my knowlege(I am
a master certified auto tech). Also, if you tried
to recharge a dead battery in "reverse polarity the
best thing that could happen to you is that the battery simply would not charge of be totally ruined. Chances are you would blow up the battery and ruin the charger. I believe JD is correct, you need to find a starte designed to spins the direction you want it to. Hope this helps.
JD 790
05-21-2001 20:13:45
Chad!
I have bought motors for liftgates that are basically starter type motors that can turn eather direction. If you pull a motor off a liftgate that is clockwise you have to get a clockwise replacement. It must have something to do with the windings and armeture and how they are made.
I asked a good starter builder once for a starter for a positive ground semi. He chuckled and told me "that starter doesn't no the difference between pos and neg ground????? ?? Sounds like you need to find a good starter and alternater builder to help you out.
steve
05-21-2001 20:17:36
 Re: Re: B stater spins the wrong way in reply to JD 790, 05-21-2001 20:13:45
JD is right. The starter is wound to turn clockwise or couter clockwise. It dont know what is + or - or 6 volt or 12.
Ron
05-21-2001 19:52:49
Some of the older tractors have a positive ground electrical system. I have a cub that has a 6 volt positive ground system. It could be that when you put the new battery in, you grounded the negative post. This would cause the starter to rotate the wrong direction if the system was originally a positive ground system.
Duey (IA)
05-21-2001 18:22:47
Chad, Unhook the starter from the tractor battery and ,with jumper cables , hook up to another battery. If it turnes the correct direction, let me know and i'll tell you how to fix it. Duey
Chad from TN
05-21-2001 18:29:50
 Re: Re: B stater spins the wrong way in reply to Duey (IA), 05-21-2001 18:22:47
Duey I've taken the starter off the tractor hooked j.cables to it and it still turns the wrong way.
Duey(IA)
05-21-2001 18:57:39
 Re: Re: Re: B stater spins the wrong way in reply to Chad from TN, 05-21-2001 18:29:50
Did you hook it to a different battery? Not the tractor battery. (Can be 6 or 12 volt.)
Steve from Tn
05-21-2001 18:22:22
Chad, you don't have your battery cables hooked up backwards, do you? Or did you have a run down battery and charge it up reverse polarity. I read somewhere on another board that this could cause a starter to spin backwards. We all do stupid stuff from time to time so it is possible.
Chad from TN
05-21-2001 18:32:28
 Re: Re: B stater spins the wrong way in reply to Steve from Tn, 05-21-2001 18:22:22
Steve the battery is new I got it out of another car,most people tell me it doesn;t matter which way the cables are hooked up
WSF
05-22-2001 13:46:30
 Re: Re: Re: B stater spins the wrong way in reply to Chad from TN, 05-21-2001 18:32:28
Is this an original starter that came with the tractor? If so, has it been worked on somewhere? I can't think how it would spin backward unless an unusual armature like from an Oliver were put into it.
Chad from TN
05-22-2001 18:40:40
 Re: Re: Re: Re: B stater spins the wrong way in reply to WSF, 05-22-2001 13:46:30
I found out what was wrong today, I got 2 starters with a trade and thought they were the same the onlt thing is the housings were different,the place where the foot switch is the opposite end of the original one making it go backwords I hope! Getting old housing rebuild tommorow!! And thanks for all your HELP!
JD790
05-22-2001 19:27:19
 Re: Re: Re: Re: Re: B stater spins the wrong way in reply to Chad from TN, 05-22-2001 18:40:40
Hi Chad Sounds like you may be going in the right direction "So to Speak"
Be sure to let us all know what fixes "Wrongway the starter"
There are lots of folks including me on this board that probably have bald spots from cratchin the old Noggin over troubles like yours.
