WD45 3point
Joel
05-21-2001 07:41:56
Is there a cheaper, maybe better,(to keep it looking closer to stock)way to change my WD45 to cat. 1 3point? From the descriptions and very few pictures I've seen the new arms don't even connect to the same points behind axel housing as the originals. Or am I missing something here?
Joel
05-23-2001 07:50:25
 Re: WD45 3point in reply to Joel, 05-21-2001 07:41:56
Hey thanks guys. Finally with the photo, and actually being able to see the snap-coupler I think it is finally sinking in past the bone. Joel
Ryan - IN
05-22-2001 06:27:39
third party image
I like the C&D Hitch. ..it maintains the factory drawbar yet allows for easy 3point conversion while keeping the snapcoupler setup intact, even the snapcoupler claws. . . .here is a pic & website listed below.
Dan
05-21-2001 11:26:37
No, the 3 pt. arms on WD (and WD45 too, I assume) attach either to the snap coupler bell or like the one I have on my WD. On it the 3 pt lift arms attach to a heavy cross T sort of piece that bolts on the drawbar under the platform. This heavy T piece has big pins on the ends that the 3 pt arms attach to so they can pivot up and down. The 3 pt. arms are then attach to my WD's two lift arms by adjustable connectors. They screw up and down for changing height of arms, etc. I like the 3 pt on the WD, but it does make it difficult to get on the tractor at times, unlike my old Ford 2N that you get on from front. I like my type because drawbar stays on..... ...but it is sometimes in the way too.
David T. (MO)
05-21-2001 10:48:48
It is possible you are missing something. ;-) The Allis arrangement has two upper load support arms mounted above a lower tow point (the snap coupler) so it is a "3-point" although it is often called a 2-point. The problem is that the tractor community has standardized on Ford's version of the 3-point where the two lower arms are both the load support and the tow point with a third upper stablizing link to keep the implements aligned properly.
I suppose if you are gifted mechanically you could figure a way to modify the WD to follow Ford's standard directly, however most people find that adding on the lower 3-point arms with attachments to the existing 2-point arms the cheapest solution to the 3-point conversion problem.
I hope that helps answers your question. If its me thats missing something ;-) you can look in the article archive for more information as there are a couple of good ones one 3-point conversions there.
