Dual hydralics on a B
Chad from TN
05-19-2001 19:00:10
Does any one make a kit to put dual hydralics on a B?
steve
05-19-2001 19:21:41
 Re: dual hydralics on a B in reply to Chad from TN, 05-19-2001 19:00:10
If you are talking about running two seperate single way hydraulic cylinders, like a belly mower lift, and a rear cylinder lift, yes. The easiest way is to run your one pressur hose from hour present pump/valve (at the rear) to a selector valve mounted below the seal fram by your leg. If you pull the new selector forward you send oil thru 1 hose to the front belly mower cylinder. If you push the selector back, you send oil thru another hose to the rear cylinder. You need the selector valve and two hoses.
Chad from TN
05-20-2001 17:48:08
 Re: Re: dual hydralics on a B in reply to steve, 05-19-2001 19:21:41
I'm needing dualremote hydralics like all the newer tractors have.
steve
05-21-2001 15:55:19
 Re: Re: Re: dual hydralics on a B in reply to Chad from TN, 05-20-2001 17:48:08
O.K. you can do that also.Just remember that your pump is low volume and big pressure. You can only use small diameter cylinders like 1.5 inch or you may run out of oil volume. Picture a new two way valve like used on a log splitter. Run your pressure hose into it as the supply. Run a hose from the new valves drain port (thru port) back to your transmission case, sump. The new valve should have two other ports for routing to both ends of a cylinder. Pull for pressure up thru one hose, push for pressure down thru the other hose. Note that your present hudraulic lever must be tied open so you get constant supply to the "new two way valve" If you put your present valve lever in the neutral or float down position, the new valve does not receive any oil. If you are connecting up "two" new two way cylinders and want them to work off different levers, then you need a double combo valve. You can buy these types of valves at Northern Hydraulics or local farm store.
