D14 hydralics
Larry
05-16-2001 04:13:12
I hooked a cylinder up to my little D14 today. Raised up fine, but wouldn't go down...whats the deal?? I have a feeling I'm not doing something right, but had to crack a line to let the pressure off to unhook the hose. The control lever acts like there is no response in the valve to let the hydralic fluid return to the tractor from the cylinder. I kept having a feeling there was a connection between the remote fitting and the traction booster, but I never could get it to let off the pressure...Thanks for any help.
Duey (IA)
05-18-2001 12:27:58
 Re: D14 hydralics in reply to Larry, 05-16-2001 04:13:12
It sounds like the hold position plunger may be broken. The plunger unseats the ball that holds the pressure. Or it may be a linkage problem. Duey
KURT
05-18-2001 02:59:40
You may only have one way hydraulics. But if the cylinder worked fine before as a double acting cylinder then you could have a binding problem in the cylinder or the control valve is not shifting properly.
