D-17 into a WD
Dave/Indiana
05-15-2001 19:09:40
I have read that a D-17 motor will bolt right in a WD. Is this true? What other modifcations will be needed? And has anybody done this before? Thanks for the Help.
Steve
05-19-2001 07:55:52
 Re: D-17 into a WD in reply to Dave/Indiana, 05-15-2001 19:09:40
I put a d-17 engine in my wd. It is really pretty easy. If I remember correctly the only things I had to change were the water pump,and I had to machine the hole in the stock WD crankshaft pulley a little deeper so the lock bolt would meet the hole in the crank. You have to use the WD water pump, and crankshaft pulley is because the D-17's are too long.
