WD-45 compression
dillweed
05-14-2001 16:42:44
Not too familiar with the Allis's but just bought a WD-45 with factory power steering. Someone had the points set at .010 and the firing order out of order - but anyway got that straightened out. My question is - the compression is 145 lbs on each cyl. Is this satisfactory for the WD-45?. That was a dry reading with the throttle butterfly wide open. Sometimes get a little blue smoke out the exhaust. Could the oil control rings be weak but the compression still be 145. Its been sitting up for 2-3 years.Thanks for your response.
KURT
05-15-2001 13:54:01
 Re: WD-45 compression in reply to dillweed, 05-14-2001 16:42:44
When I bought my farmall H I did a compression check of all 4 cylinder and I got 90 psi out of all 4. It is a very good running machine. Nothing runs like and international.
KURT
05-15-2001 13:53:42
Tom
05-14-2001 16:49:32
The WD/WD-45 Service Manual says for a 45 that compression should be 130 lbs. Never mind the bit of blue smoke. Run it. If it uses a little oil the oil leaking up past the rings will keep them well lubed. Maybe your smoke is a result of oil leaking down the intake valve stem too.
