Here is the full story.. HAve AC B that my cousin bought. I have helped out a little to get it running. It ran rough when he bought it. It is a 38 and only has hand crank, no electrics. He could not get it started when he got it home. He rebuilt the carb. Still no start, no pull starting either. It had suppression wires on it. I put copper wires, new plugs, new points and condensor, and cleaned rotor and cap. It started when pulled. I left. Never started again. checked timing. Way off. The impulse was off and the rotor location was off. I reset the impulse by turning the govenor until it clicked when TDC was achieved. Reset the rotor so that when I clicked on TDC on #1 it then was pointing as #1. IT fired right up. (by the way the timing marks on the geard were way off now, someone had been in the motor) I started several times and ran smoothly. I noticed the carb was out of adjustment but then asked here and now know how to adjust it. He dismantled tractor to istall foot brakes, new torque tube for starter istallation, and PTO and hydraulics. Now it is reassembled and the magneto is acting up again. The impulse(the clicking) only works sometimes. They were going to reset the timing from TDC to Fire so that it had the proper advance. Sometimes it clicks, sometimes not. THey took off the mag, turned it by hand, everything fine. put it back on and it works ten times or so, then stops, then it starts clicking again. any ideas????? ??
Thanks.
