WD and front end?????
Jim Tanner
05-13-2001 17:59:28
Anyone have any knowledge or cure for my problem? Every time I try to go up a slight grade with my WD it will lift right off the ground. I have had it also do it just taking off. With an implement on or off! Any cures or it the nature of this beast (HP and size) Help!
Aaron
05-13-2001 19:11:38
 Re: WD and front end????? in reply to Jim Tanner, 05-13-2001 17:59:28
What kind of grade are we talking about. I've had mine up some hills and it stays right on the ground. I guess if you are having a problem on ground you consider otherwise safe to drive on, you can put calcium chloride in your front tires. Stuff weighs like 13 lbs a gallon and 'd think you could get a fair amount of weight in the 2 front tires.
Aaron
Dan
05-15-2001 04:35:03
 Re: Re: WD and front end????? in reply to Aaron, 05-13-2001 19:11:38
I have same reaction as you, Aaron. I have not had that problem at all. Even if I pop the clutch going up a pretty steep incline, front end would not be a concern? Perhaps if I were hooked high above drawbar on tractor it might then react.
