Zenith Carb Poor Idle
Johnny N.C.
05-11-2001 20:28:10
can not adj carb no vac leaks external.New manifold,new kit in carb,rough idle,best with choke 1/3 out where do these carb,s give this kind of trouble ? internally.
Mike
05-12-2004 13:22:09
 Re: Zenith Carb Poor Idle in reply to Johnny N.C., 05-11-2001 20:28:10
I just bought a "C" mine ran the same way the main jet on the bottom of the bowl was clogged slightly take plug out and blow air back through.Also check the tank may have rust or debree blocking the outlet hole take sediment bowl off and add a short piece of five sixteenth inch pipe to extend it up off the bottom a little bit.
Aaron
05-12-2001 21:43:43
Just played with that same problem on mine this morning. This may sound crazy, but try running it and opening the bowl drain a little and see if that clears it up. If it does, there is a passage that may be plugged. It runs from right behind the choke butterfly along the outside of the casting and angles back up to the center of the carb. I used a piece of wire in a drill this morning to clean mine out. Ran like a champ when I got it cleaned.
Aaron
Johnny NC.
05-13-2001 17:35:16
 Re: Re: Zenith Carb Poor Idle in reply to Aaron, 05-12-2001 21:43:43
Thank,s Aaron will ck that, it pay,s to post your
problems,there are allways good people to help''
you when you are at whit,s end.Thank,s again
Dick L
05-12-2001 07:05:09
third party image
That carburetor is does not have much to give problems if it is clean and the float setting is correct. The big word is CLEAN. I realy don't think it is a carburetor problem. I would guess that if you get the timing set to specs as well as the points that you will be able to adjust the carb. A couple of pictures to mull over
Johnny N.C.
05-12-2001 20:45:16
 Re: Re: Zenith Carb Poor Idle in reply to Dick L, 05-12-2001 07:05:09
Thanks Dick L for the responce and photo,s will
double check your suggestons
Dave-Ontario
05-12-2001 20:03:12
Hi Dick, Just a note to say thanks for the pics of the Zenith carb. Will keep it on file. You never know when you might need it. Dave
mushroom steve (wi)
05-12-2001 16:10:02
Thanks for the pics.("one man gathers what another man spills"-stephen hunter)
