AC-190 Hydraulics
Tony Crivella
05-09-2001 17:57:26
I have a 190 Allis and I want to run a Hydraulic motor off of the remolts,the motor is rated at 12 gallons per min. Will the 190 handle it?? What is the Flow rate of the 190?? The equipment manufactor says thehyd motor needs the tractor to have a 22 gallon per min...Has anyone else ever ran a hyd motor off the rear before????
KURT
05-13-2001 10:59:51
 Re: AC-190 Hydraulics in reply to Tony Crivella, 05-09-2001 17:57:26
I would look at the maximum RPM allowed on the motor. The shaft speed may not handle it. But if you were to put in a flow reducer valve to the motor and have the excess flow piped off to the main tank it may work.
