To all of you who have given me tips on trying to solve my sputtering/coughing problem on my '49 B, I do appreciate it, a lot.But, it's still happening. For those that haven't read my previous 2 posts. When I try to go up the slightest hill or put a load on my B, it starts to cough or sputter. To date, I have cleaned everything fuel related, adjusted the carb til I'm stinkin with gas fumes, cleaned plugs, re-gapped them, and replaced fuel line. Just this week I finally got around to replacing the points and condensor as advised. Unfortunately, no change. I have not checked the timing yet, because I don't have a timing gun, nor a hand crank (static timing). I plan to buy a timing gun. How do I set the timing with a gun? Better said - what marks do I need to line up with on the flywheel? I know the IT manual says 30' B, but how do I know from the flywheel that I'm there? Are there ticks on the flywheel to line up to? If this doesn't fix it, then I'm going to be clueless. As I've said before, the tractor will purr like a kitten, and run on level or downhill surfaces. But, start going up a hill and it starts to cough and sputter. When you have the air filter off the carb, it almost sounds like a popping noise. The air filter somewhat muffles it so its more like a sputter. Anyway, if timing doesn't do it, then I'm really scratching my head. I haven't replaced plug wires, dist. cap, or spark plugs. The spark plugs look pretty new. Thanks in advance, Matt
