Allis Chalmers 5040
Dave
05-07-2001 16:01:16
When I push the clutch in and try to switch the lever to engage the pto the clutch does not seem to disengage and the lever grinds. There was no indication of a problem before. Does anyone have an idea if there is some kind of adjustment to the
clutch or other any other areas I might look at.
Any help/hints about this problem would be greatly
appreciated. The clutch works fine for the
transmission, just pto is a problem.
Jason
05-08-2001 16:31:04
 Re: Allis Chalmers 5040 in reply to Dave, 05-07-2001 16:01:16
Open the little cover on the side. Then on the pressure plate you will see 3 little bolts 10mm heads ans 13mm jam nuts loosen the jam nut and back the screw out until you have around .060 clearance between the end of the bolt and the dog leg lever.
You will have to rotate the engine to find the bolts. Once you look at it you will be able to see what I am talking about. If not let me know.
