WD overhaul for more hp
Joe Ward
05-07-2001 07:08:46
I am thinking of doing an engine overhaul on my WD. Can I make it into a WD-45? and get more hp from it.
Thanks.
Gordon in IN
05-07-2001 18:56:35
 Re: WD overhaul for more hp in reply to Joe Ward, 05-07-2001 07:08:46
If you want more, lots more power, get a D17 AC engine or a "Gleaner" combine engine (by Allis Charmers) and you will have a higher horsepower, larger displacement, higher compression, higher speed engine with a balanced crankshaft and higher oil pressure. These engines will "bolt right in" to the WD. It will make a WD a "Screamer" it will also wear the gears and bearings faster. Good luck Gordon in IN
Aaron
05-07-2001 10:36:31
Yup, just add the 45 crank ( bolts right in. 45 head, carb, etc are all good. For a bit more, if you have been converted to 12 volt, you could use a D17, 175, etc overhaul kit. Ups the compression a bit and they all drop right in.
Aaron
Steve
05-19-2001 08:07:50
 Re: Re: WD overhaul for more hp in reply to Aaron, 05-07-2001 10:36:31
If you use the 45 crank you better use the 45 pistons too or you'll have major problems when you try to start it. I have a D-17 engine in my wd, much better. If you use a D17 or E Gleaner engine you will need the WD water pump and crank Pulley.
