Magento Problems
David Peime
05-07-2001 02:47:37
My Allis Chalmers Model B has a car coil attached to it. The ground wire is connected to the centre of the coil with a ground wire going to the negative side. The positive side of the coil coils to the on/off switch on the istrument panel. This wire is live when the switch is turned on. Can anyone tell me what may be wrong with the magento.
Phil Auten (TX)
05-07-2001 04:04:50
 Re: Magento Problems in reply to David Peime, 05-07-2001 02:47:37
The mag coil is probably bad. The previous owner either couldn't find a replacement mag coil or didn't want to pay for one. Substituted a car coil and made it into a distributor. My '39 RC is in this same situation.
Phil
David Peime
05-14-2001 02:07:28
 Re: Re: Magento Problems in reply to Phil Auten (TX), 05-07-2001 04:04:50
Phil, thanks for the reply. How would I know if the mag coil is bad. And can it be fixed and how.
Tom Lyman
05-07-2001 20:37:00
Does that system work ok?
Tom
