CA almost ready to rumble, Now I Need implements.
Mike (IN)
05-06-2001 20:28:30
Our 1954 CA is close to being ready to run again.
Was wondering where I might find implements for it in central Indiana or even westcentral Ohio? It does not have a snap coupler.
Was also wondering what the chances are that I could pull a 2-bottom IH "Little Genius" plow with it?
It does have rear wheel weights on it, and I know it is basically the same hp as a Farmall H (which is what I usually plow with), but the H is about 3,000lb heavier.
Phil Auten (TX)
05-07-2001 04:01:24
 Re: CA almost ready to rumble, Now I Need implements. in reply to Mike (IN), 05-06-2001 20:28:30
Fill your rear tires with water or a water/antifreeze mix. You'll be amazed at the difference that will make when you plow!
The 2-bottom plow should work well with the CA.
Phil
