Wd 45 rim
R.Farrell
05-06-2001 13:48:46
Need set of rims for the back would like to put 14.9 on it on fix rims can I do this need to know where to get rims
Dan
05-07-2001 05:58:56
 Re: wd 45 rim in reply to R.Farrell, 05-06-2001 13:48:46
If you wanted to go even wider, take a look at AC Combine rims. Can often get rims and tires for very reasonable. They are a little shorter but fit.
steve
05-07-2001 04:38:54
Where are you located? I know of some around here (central wi)...too expensive to ship though...I've been told to check the shows for about anything you need and those rims should be easy to find...popular tractor.
