Allis Chalmers Model B 1938/39?
jee double you
05-03-2001 16:10:11
Does any one here know the specs on the crank. I want to know if I need oversized bearings. Also any other specs regarding an engine overhaul..
John Burkland
01-17-2003 20:34:28
 Re: Allis Chalmers Model B 1938/39? in reply to jee double you, 05-03-2001 16:10:11
I recently purchased a 1939 Allis Chalmers Model B , Ser# B12787.
This tractor has only a crank start, i.e. no battery, starter, wiring, etc.
I need to get an operator/maintenance/parts manual.Can you help?
What year did the starter/battery show up?
Thanks, johnb
Tyler(WA)
05-04-2001 07:47:48
The specs are not consistent with these older engines and you can't tell what work was done before you.
Most parts suppliers for these older engines ask you to "mic" your cranks and order accordingly. They'll send you the correct bearings for your engine that way.
Trying to compare a 1938 engine to a modern block..... well?.... "we must not be in Kansas anymore, Toto." ;-)
