Starting an AC 180 diesel
kevin-k
05-03-2001 14:27:51
Greetings from a city-boy turned hobby farmer!
I just got a 1970 AC 180 diesel and am having trouble starting it sometimes. It came with some sort of aftermarket ether injection system with a push button on the dash, but the canister is empty. After reading about the possible drawbacks to using ether, I'm wondering if I should bother refilling it. The tractor does have a block heater but it's 70 deg. out. Will plugging it in still help start it?
Any advice would be appreciated!
Kevin K.
grinny
05-03-2001 19:55:58
 Re: Starting an AC 180 diesel in reply to kevin-k, 05-03-2001 14:27:51
Plugging it in will help, but a half hour wait is needed before results will be noticed. Don't know your climate, but usually by this time of year anywhere but Alaska, a diesel should start reliably without starting aids (ether, block or intake heaters, booster batteries, etc). Cranking speed is critical on a diesel engine. If that sucker ain't spinnin over to beat the band, it ain't gonna start period. 160-200 rpm is usually required to start. Problem with checking cranking speed is that a phototach is usually required to measure cranking speed. If speed is OK, then I would investigate injector problems, or low compression. This is I believe a direct injected engine so it should start fairly easily above 40 degrees F. Good luck.
