Conversion CA from 6 volt to 12 volt system
Morley
04-29-2001 08:51:42
Hi I require advice regarding using a CA on a field sprayer which has a compressor for a foam marker which is 12. Is it run a line from the 6 volt system ie by from the battery to a coil and step the voltage up to 12 volt which would then power the 12 volt compessor for the foam marker
Thanks
Morley
Dave-Ontario
04-29-2001 12:23:29
 Re: Conversion CA from 6 volt to 12 volt system in reply to Morley, 04-29-2001 08:51:42
Hi Morley, You can't step up the voltage with dc current which is what you tractor will be. Transformers only work on ac.
steve
04-29-2001 14:01:47
 Re: Re: Conversion CA from 6 volt to 12 volt system in reply to Dave-Ontario, 04-29-2001 12:23:29
it might be easier to just take the battery out of your truck and set it on the sprayer when needed. charge it up when you get back. Unless your tractor generator is bad and you want to convert over the entire tractor system to 12 volt.
