Allis chalmers paint
darin stoll
04-26-2001 14:35:52
I have just aquired an Allis "B". It's a 1938 model. The dealer close to here says the paint should be Osage Orange, but it is no longer available. Does anyone know where you can get it or a paint code so I can have our local parts store mix me some up? Thanks for any info.
Mike
05-23-2002 13:14:26
 Re: allis chalmers paint in reply to darin stoll, 04-26-2001 14:35:52
Where can we get decals for a Allis Chambers WD, 1951 we believe. Thanks,
Tyler(WA)
04-27-2001 13:50:26
You can still get original Persian Orange from the AGCO dealer. It's factory paint too.
JW (MI)
04-27-2001 01:05:20
It's Persian Orange. If you look on the left hand side of this web page you see a section called Research & Info. Paint codes are on the very bottom. Your local paint supplier should be able to mix it using this code. Make sure you don't use Allis Chalmers Orange 2 as it's not the same as the original. Good luck!
