Calling AC pros
advice needed
Timber Beast
04-25-2001 19:58:24
Howdy - have a 1952 AC WD has wide front & in decent mech shape. Have made a 3Pt adapter for it. Looks like it will work well with a disc/grader blade/ etc but due to original drawbar, will not accept a 3Pt plow, nosepiece won't clear drawbar. Have a 2 bottom AC plow that have never used - is not snap coupler, but similar. Has straight pin on nose of plow, then assume goes to AC lift arms somehow( parts missing) Any advise? How do they work? thanks!
Aaron
04-26-2001 18:27:43
 Re: Calling AC pros - advice needed in reply to Timber Beast, 04-25-2001 19:58:24
If you check out eBay, you can find a manual for the plow. It's called a WD plow. It uses the lift arms, and slides under the drawbar (with the bar floating) and uses a hitch pin for pull, and the pin in the front goes over the drawbar for lifting.
Aaron
